Convention | Description | Example |
Menu >Menu command | A menu item followed by a menu command | Click Settings > Preferences > Edit. |
drop-list | A list of options that drops down when a user clicks a down arrow button | Select a profile from the Profile drop-list. |
A note containing information that is important to the preceding steps. It may describe conditions under which the procedure can be performed. | Enable Flatten audio and background video if your browser can only support a single track for audio and video. | |
A tip containing suggestions for performing the preceding steps. It may present alternatives to the steps, or other benefits and uses of the procedure. | For best results, use a tripod when you shoot photos and videos that you want to use in your stop motion animation project. |
