How to create a Highlight Reel movie
With an understanding of how Highlight Reel works, and the options and settings available, you are ready to build your first Highlight Reel movie.
To create a Highlight Reel movie
1 Open
Highlight Reel (In the VideoStudio
Library panel, click the
Highlight Reel button
Note: The
Highlight Reel button is available only when you select a custom folder in the media Library (a folder that you have created by clicking the
Add a new folder button
2 Click the
Folder button
, and choose a previously created folder, or click the
New Folder button
, and type a folder name.
The new folder appears in the folder list and is selected by default.
3 If you need to import media, click the
Import Media button
, choose
Import Media Files or
Import Media Folder, navigate to and select the media you want, and click
Open.
Supported media files are added to the Highlight Reel Library.
4 If you want to select specific videos and photos for your movie, use the filter and sorting features to find the media you want, and click the upper-right corner of each thumbnail to add a check mark.
5 Click the
Settings button
, and choose a
Movie mode and
Movie settings. For more information, see
Highlight Reel settings.
Note: Auto takes full advantage of the automation features.
6 Click Create.
The compilation process takes several seconds or minutes, depending on the size and number of media files it must analyze.
The movie appears in the Timeline when processing is complete.
7 Use the playback controls in the Navigation area to review your movie.
9 When you ready to export your movie, click OK at the bottom of the window.
The movie is exported as a .vsp file and is added to the VideoStudio Library.
