F3 | Set mark-in |
F4 | Set mark-out |
L | Play/Pause |
Ctrl + P | Play/Pause |
Space | Play/Pause |
Shift + Play button | Play the currently selected clip |
K | Return to the start of clip or project |
Home | Return to the start of clip or project |
Ctrl + H | Return to the start of clip |
End | Move to the end segment or cue |
Ctrl + E | End |
D | Previous frame |
F | Next frame |
Ctrl + R | Repeat |
Ctrl + L | System Volume |
S | Split Video |
Tab | Toggle between the Trim Handles and Scrubber. |
Enter | When the left Trim Handle is active, pressing [Tab] or [Enter] switches to the right handle. |
Left | If you pressed [Tab] or [Enter] to make the Trim Handles or Scrubber active, use the Left-arrow key to move to the previous frame. |
Right | If you pressed [Tab] or [Enter] to make the Trim Handles or Scrubber active, use the Right-arrow key to move to the next frame. |
ESC | If you pressed [Tab] or [Enter] to activate and toggle between the Trim Handles and Scrubber, you can press [Esc] to deactivate the Trim Handles / Scrubber. |
