Saving and deleting transitions
You can collect your favorite transitions from different categories and save them in the My Favorites folder. This way, you can easily find the transitions that you use most often. You can also delete transitions that you do not use.
* To save a transition in My Favorites
1 Select the thumbnail of the transition.
2 Click the Add to My Favorites button to add the transition in the Favorites Library list.
* To delete a transition from a project
Do one of the following:
Click on the transition to be removed and press [Delete].
Right-click on the transition and select Delete.
Drag to separate two clips with transition effect.
