Saving HTML5 video files
If you chose File > New HTML5 project at the start of your project, the HTML5 Files output option displays in the Share workspace.
HTML5 projects can include hyperlinks and chapters. This video format is compatible with browsers that support HTML5 technology, including most of the latest browsers and Safari, which is used on iPhone, iPad, and iPod touch devices.
You can save your HTML5 video projects directly to cloud-based storage services, such as Dropbox and Google Drive. For more information about sharing from these cloud-based services, refer to the Dropbox or Google Drive Help.
For more information about starting an HTML5 project, see “Creating new projects” on page 11.
Saving an HTML5 project as an editable VideoStudio project
If you might need to edit the project later and output it to formats other than HTML5, you can save a copy of the project to the native Corel VideoStudio Pro format (*.vsp).
To create an HTML5 video folder
1 In the
Share workspace, click the
HTML5 Files button
2 Modify any of the following settings:
• WebM — In the Video format area, mark the WebM format check box if you want to use the WebM format. (Recommended)
• Dimensions — Choose the screen resolution and aspect ratio from the drop-list.
• Flatten audio and background video — In the Dimensions area, mark this check box if you are not sure if your browser supports more than a single video or audio track. (Recommended)
3 In the Project folder name box, type a name.
4 In the File location box, specify the location where you want to save the folder.
If you want to save it to a cloud-based storage service, browse for the local folder of your preferred service.
5 Set any of the following options:
• Create Preview Range Only — renders only the section of video that is selected between the Trim Markers in the Preview panel.
• Enable Smart Render — analyzes a video for any previously rendered sections and renders only the new or revised sections. This can reduce rendering time significantly, but is not available for WebM output.
6 Click Start.
You can view the video from your output folder by opening Index.html in your browser.
Press the [Esc] key to cancel the rendering process.
A progress bar appears when you render a video. You can use the buttons on the progress bar to do the following:
• Click the
Pause/Play button
on the progress bar to pause and resume the rendering process.
• Click the playback button
to enable the preview while rendering or stop the preview to reduce rendering time.
The rendering progress bar
To save an HTML5 project as a Corel VideoStudio Pro project (VSP)
1 In the
VideoStudio Project button
2 In the Subject box, type your subject information.
3 In the Description box, type a project description.
4 From the File format drop-list, choose a VSP version.
5 In the File name box, type a file name.
6 In the File location box, specify the location where you want to save the project.
7 Click Start.
