Saving to video files for computer playback
VideoStudio lets you save your movie project to video file formats that you can playback on computers.
Before rendering your entire project into a movie file, make sure you first save it as a VideoStudio project file (*.vsp) by clicking File > Save or Save As. This lets you return to your project at any time and make edits.
* To create a video file for computer playback
1 In the Share workspace, click the Computer button .
2 Click one of the following buttons to view and choose the profile for your video:
AVI
MPEG-2
AVC/H.264
MPEG-4
WMV
MOV
Audio
Custom
If you want to use the Project Settings for the video file, enable the Same as Project Settings check box located above the buttons.
3 In the Profile or Format drop-list, choose an option.
If you want to create a custom profile, click the Create Custom Profile button . For more information, see Working with custom profiles in the Share workspace.
4 In the File name box, type a file name.
5 In the File location box, specify the location where you want to save the file.
6 Set any of the following options:
Create Preview Range Only — renders only the section of video that is selected between the Trim Markers in the Preview panel.
Enable Smart Render — analyzes a video for any previously rendered sections and renders only the new or revised sections. This can reduce rendering time significantly.
7 Click Start.
Press the [Esc] key to cancel the rendering process.
A progress bar appears when you render a video. You can use the buttons on the progress bar to do the following:
Click the Pause/Play button on the progress bar to pause and resume the rendering process.
Click the playback button to enable the preview while rendering or stop the preview to reduce rendering time.
The rendering progress bar
