Part | Description | |
![]() | Storyboard View | Displays your media thumbnails in chronological order. |
![]() | Timeline View | Lets you perform frame-accurate editing of your clips on separate tracks, add and position other elements such as titles, overlays, voice-over and music. |
![]() | Replace Mode | Lets you drag and drop clips from the Library to replace clips on the Timeline. When not enabled, you must press and hold the CTRL key to replace timeline clips with Library clips. |
![]() | Customize Toolbar | Lets you hide or show individual toolbar tools. |
![]() | Undo | Undoes the last action. |
![]() | Redo | Repeats the last action that was undone. |
![]() | Slip tool | Lets you drag a trimmed clip in the Timeline to change which frames show. Clip duration in the Timeline does not change. |
![]() | Stretch tool | Lets you change the speed of the clip by interactively stretching or compressing the clip in the Timeline. |
![]() | Roll tool | Lets you drag the out point/in point between two trimmed clips in the Timeline, therefore adjusting the duration of the two clips. |
![]() | Slide tool | Lets you adjust the end points for a trimmed clip in the Timeline without affecting the duration of the adjacent clips. |
![]() | Record/Capture Option | Shows the Record/Capture Option panel, where you can capture videos, import files, record voice-overs and take snapshots. |
![]() | Sound Mixer | Launches the Surround Sound Mixer and the multitrack Audio Timeline, which lets you customize your audio settings. |
![]() | Auto Music | Launches the Auto Music Options Panel for adding background music to your project in a variety of styles and moods. You can set the music to match the duration of your project. |
![]() | Track Motion | Launches the Track Motion dialog box, which lets you create tracking paths of particular elements in selected video clips. |
![]() | Subtitle Editor | Launches the Subtitle Editor dialog box, which lets you detect and organize segments to easily add titles in selected video clips. |
![]() | Multi-Camera Editor | Launches the Multi-Camera Editor and imports any of the selected media. |
![]() | Time Remapping | Launches the Time Remapping dialog box, which lets you use speed controls to slow down, speed up, reverse, or freeze frames in a video clip. |
![]() | Mask Creator | Launches the Mask Creator dialog box, which lets you create video and still masks. |
![]() | Pan and Zoom | Launches the Pan & Zoom dialog box, which lets you apply pan and zoom effects using keyframes. |
![]() | 3D Title Editor | Launches the 3D Title Editor dialog box, which lets you create and save three-dimensional titles. |
![]() | Split Screen Template Creator | Launches the Template Editor where you can create or edit split screen templates that let you play multiple videos in a creative layout. |
![]() | Painting Creator | Launches Painting Creator where you can record painting, drawing, or writing strokes as an animation or still image that can be applied to your project as an overlay effect. |
![]() | Zoom in and Zoom out | Lets you adjust your view of the Timeline by using the zoom slider and buttons. |
![]() | Fit Project in Timeline Window | Adjusts your project view to fit the entire span of your Timeline. |
![]() | Project Duration | Shows the total duration of the project. |
