Moving files
Note:  Some audio files are protected with digital rights management (DRM) and cannot be moved.
To move audio files, follow these steps:
1	Click Batch Convert and Transfer on the Music - Audio project tab.
Roxio Audio Converter opens.
2	Click Add Tracks, and use the Media Selector dialog to select the audio files or tracks you want to convert. Files can be selected from a hard disk, CD, DVD, or iPod. You may be able to add audio files from other portable devices, depending on the file and device type.
3	Click Convert.
4	Unless you want to keep the original files, clear Keep original files.
Warning:  The original files will be deleted.
5	In the Conversion settings box, select Keep original format.
6	Choose the subfolder structure to be used:
n	To keep the same folder structure, clear the Subfolder / file name structure check box.
n	To move the files to a folder structure based on audio tags (such as artist and album), select the Subfolder / file name structure check box. From the drop-down list on the left, select the desired folder structure. In the drop-down list in the middle, set the file naming convention to Original file name.
7	In the Target folder box, specify the location on the hard disk or network where you want to store the files.
8	Select what to do if a file with the same name already exists in a folder.
9	Click Convert.
See also:
