Selecting Smart Objects
By default, certain objects already exist in layouts when you create a new project. These are Smart Objects, which Label Creator can populate with information it retrieves about your CD or DVD from the disc or from looking online. Label Creator propagates the information in the Smart Objects across all layouts in a project. For example, if you enter information into the Title Smart Object in a Disc Layout, all other layouts in that project, such as the Front and Back, will have that title.
Label Creator layouts have the following Smart Objects:
n Artist | n File/Folder List |
n Background | n Logo |
n Chapter List | n Movie Duration |
n Content Illustration | n Number of Files |
n Content Media Type Icon | n Overspan Disc Number |
n Copyright | n Picture Index |
n Date | n Serial Number |
n Description | n Title |
n Disc Type Icon | n Track List |
n Disc Volume Label | |
注意: Some Smart Objects only appear in certain layouts. For example, only the Audio template has the Track List object.
For information about changing the content and formatting of Smart Objects, see
テキストとグラフィックを操作する.
To choose which Smart Objects to show on your layout:
1 In the Edit Layout area, select Show/Hide Smart Objects.
2 Select the Smart Objects you want to appear in your layout. Clear the others.
3 Click OK.
The Smart Objects you selected appear on the right side of the Layout area.
注意: When working with your layout, you can hide Smart Objects you don’t want to see by selecting them and using the Delete key. This only works for Smart Objects. Other objects actually will be deleted instead of hidden.
以下も参照してください:
