Drawing circles and ellipses
      You can draw circles and ellipses.
      To draw a circle or ellipse
        On the Tools toolbar, select the
Ellipse tool
        Note:  If you want to place the circle or ellipse on the current vector layer, mark the
Create on Vector check box on the Tool Options
 palette
. If no vector layer exists, marking this check box creates one for the circle or ellipse. If this check box is unmarked, the circle or ellipse is placed on a raster layer. Placing a circle or ellipse on a vector layer makes it easier to edit.
        On the Materials palette, click the
Background and Fill properties box, and choose a fill color.
        Click the
Foreground and Stroke properties box, and choose an outline color.
        4
        On the Tool Options palette, click one of the following buttons:
Draw Circle
Draw Ellipse
If you want to display the shape’s nodes, mark the
Show Nodes check box.
        5
        Drag to draw the shape.
        6
        Click the
Apply button
          |  | Mark the Show Nodes  check box. Type or set values in the Radius X  and Radius Y  controls. |
          | Set the center horizontal (center X) and vertical (center Y) position | Mark the Show Nodes  check box. Type or set values in the Center X  and Center Y  controls. |
      You can save Tool Options palette settings as presets. For more information, see Using and creating presets.
      If you have not displayed nodes in the shape, you can still set the radii and the center horizontal and vertical positions by clicking the Edit Mode button  on the Tools Options palette.
