Drawing lines
      You can draw straight lines, freeform lines, and line segments. You can edit the nodes in a line to create curves.
      You can also adjust the line options of existing vector objects.
      To draw a line segment
        On the Tools toolbar, choose the
Pen tool
        Note:  If you want to place the line segment on the current vector layer, mark the
Create on Vector check box on the Tool Options palette.
 If no vector layer exists, marking this check box creates one for the line segment. If this check box is unmarked, the line segment is placed on a raster layer. Placing a line segment on a vector layer makes it easier to edit.
        On the Materials palette, click the
Foreground and Stroke properties box, and choose a color for the outline.
        If you are drawing connected line segments and you want to apply a fill, click the
Background and Fill properties box, and choose a color for the text fill. If you do not want the line segments to have a fill, click the
Transparent button
        Note:  If you are drawing a single, unconnected line segment, it is not necessary to choose settings from the
Background and Fill properties box.
        4
        On the Tool Options palette, click the
Draw Lines and Polylines button
        5
        Choose a line style from the
Line Style drop-list.
        6
        Type or set a line width (in pixels) value in the
Width control.
        7
        Drag in the image window to create the line.
        8
Apply button
          | View the object’s nodes while drawing | Mark the Show Nodes  check box. |
          | Smooth the appearance of the line | Mark the Anti-alias  check box. |
          |  | Select an option from the Join  drop-list. If you select Miter Join , you can type or set a value in the Miter limit  control to set the degree of pointedness. |
          | Create a vertical, horizontal, or 45-degree line | Hold down Shift  while dragging. |
          | Connect each line segment | Mark the Connect Segments  check box. |
      You can save your settings in the Tool Options palette settings for subsequent use. For more information about saving settings as presets, see Using and creating presets.
      To draw a curved or straight line
Pen tool
Draw Point to Point button
        4
        Do one of the following:
To create a straight line, click where you want the next node.
To create a curved line, click and drag. When the curve is the right shape, release the mouse button.
If you want to draw lines at fixed angles (45 degree increments), hold down
Shift as you drag.
To draw a free-form line
Pen tool
Draw Freehand button
      To draw line segments
Pen tool
Draw Line and Polylines button
