Drawing rectangles and squares
      You can draw squares and rectangles.
      To draw a rectangle or square
        On the Tools toolbar, select the
Rectangle tool
        Note:  If you want to place the rectangle or square on the current vector layer, mark the
Create on Vector check box on the Tool Options
 palette
. If no vector layer exists, marking this check box creates one for the rectangle or square. If this check box is unmarked, the rectangle or square is placed on a raster layer. Placing a rectangle or square on a vector layer makes it easier to edit.
        On the Materials palette, click the
Background and Fill properties box, and choose a fill color.
        Click the
Foreground and Stroke properties box, and choose an outline color.
        4
        On the Tool Options palette, click one of the following buttons:
Draw Rectangle
Draw Square
If you want to display the shape’s nodes, mark the
Show Nodes check box.
        5
        Drag to draw the shape.
        6
        Click the
Apply button
          | Set the radii for the shape’s corners | Type or set values in the Horizontal Radius  and Vertical Radius  controls. |
          | Choose a line style and width | Choose an option from the Line Style  drop-list, and type or set a value in the Width  control beside the drop-list. |
          |  | Mark the Anti-alias check box. |
          | Change the way the line segments join | Choose an option from the Join  drop-list. If you choose Miter join , you can also type or set a value in the Miter Limit  control. |
          |  | Mark the Show nodes  check box. Type or set values in the Width  and Height  controls. |
          |  | Mark the Show nodes  check box. Type or set values in the Left  and Top  controls. |
      You can save your settings as a preset. For more information, see Using and creating presets.
