You can edit the contours and paths of vector objects. You can join contours by connecting their end points. You can also reverse the direction of paths and contours. The direction of a contour flows from the start node to the end node. When you place the cursor over the start node, a "START" message appears next to the cursor. When you place the cursor over the end node, an "END" message appears. If the object has a closed path, a "CLOSE" message appears.
For more information about the different types of nodes, see Modifying lines and curves.
      You can also join contours manually. Drag a node on the first contour over the second contour’s start or end node. When the cursor displays "JOIN," release the mouse button.
      The path or contour breaks and a new node is added on top of the current node. The node square changes to a node-on-node indicator  .
      You can also move a contour by double-clicking a node to select all nodes, and then dragging one of the nodes.
      You can adjust the offset from the original contour by adjusting the settings in the Duplication X and Duplication Y controls on the Tool Options palette.
      You cannot delete a path. A path is deleted with its object or when all of its contours are deleted.
