Modifying lines and curves
You can edit the properties of lines and curves. You can reshape a curve by changing its nodes the shape of the contour at a node by changing the node type, by modifying its line segments on either side of a node, or by connecting line segments. You can also cut a line segment. When you cut a closed path or contour, you open it. When you cut an open path or contour, you create two separate contours.
To edit a line or curve
On the Tools toolbar, choose the
Pen tool
On the Tool Options palette, click the
Edit Mode button
4
Modify any of the settings on the Tool Options palette.
You can also edit the curve by clicking the Pick tool
, selecting the curve, and modifying any of the settings on the Tool Options palette.
To adjust a line segment by changing the nodes
Pen tool
Edit Mode button
Right-click a node, choose
Node Type, and select one of the following options:
Convert to Line — straightens the segment before and after the node
Line Before — straightens the segment before the node
Line After — straightens the segment after the node
Curve Before — curves the segment before the node
Curve After — curves the segment after the node
To connect multiple line segments
Create as many connected line segments as you want.
On the Tool Options palette, click one of the following buttons:
Start New Contour
— connects line segments in an open shape
Close Selected Open Contours
— connects line segments in a closed shape
Click the
Apply button
You can save a set of Tool Options palette settings as presets. For more information, see Using and creating presets.
To cut a line segment
From the Tools toolbar, choose the
Pen tool
Knife Mode button
Drag across the contour where you want to cut it.
When you click the Knife Mode button, you can cut through all selected contours in an object.
