Choosing effects
You can choose effects by using the Effects menus, the Instant Effects palette, or the Effect Browser.
You can customize most effects by adjusting their settings in dialog boxes. The dialog boxes for applying effects contain several common features:
The Before pane shows the original image, and the After pane lets you preview the image with the current settings applied.
The Load Preset drop-list is set by default to Last Used. Presets let you apply the same settings to multiple images.
To save and load your own presets for effects, see Using and creating presets.
An example of a dialog box for an effect.
Using the Instant Effects palette
You can quickly apply preset effects by using the Instant Effects palette. It is an easy way to apply an effect when you don’t want to adjust controls. When you create a preset in any effects dialog box, your preset automatically displays in the Instant Effects palette in the User Defined category. In the AI Style Transfer category, you can control the effect with Strength, Color Match, and Smooth Image controls.
Using the Effect Browser
You can use the Effect Browser when you want to preview multiple effects before applying them to your image. The Effect Browser displays the presets that come with PaintShop Pro as well as any that you create.
To display the thumbnail previews that you see in the Effect Browser, PaintShop Pro applies an effect’s default preset and any presets that you saved to the image. The preset is saved as a script in the file format for PaintShop Pro (PspScript).
The Effect Browser displays thumbnails that let you preview and choose effects.
To choose an effect from the Effects menu
From the
Effects menu, choose an effect category, and choose an effect. (For example, choose
Effects
Distortion Effects
Twirl.)
For most effects, a dialog box appears.
Specify the desired settings, or choose a preset from the
Load Preset drop-list.
You can preview the effect in the After pane.
Note: Presets are not available for all effects.
Click the Save Preset button  , type a name in the Preset name box, and click OK.
Reset settings to default values
From the Load Preset drop-list, choose Default.
Limit an effect to a specific area
Make a selection before choosing the effect.
For information about creating selections, see Creating selections.
To choose an effect from the Instant Effects palette
In the Instant Effects palette, choose a category from the drop-list below the preview at the top of the palette.
If the Instant Effects palette is not displayed, choose
View
Palettes
Instant Effects.
Click a thumbnail to apply the effect to the preview in the palette.
To apply the effect to the active image or the selected images, double-click a thumbnail.
With the exception of the AI-Powered effect, effects are cumulative; each time you double-click, the new effect is added to the previous effect.
To undo an effect, click the
Undo button
(Adjust and Edit tabs).
From the Manage tab, if you apply effects to an image that is in a RAW file format, a JPEG version of the image is created.
Custom presets (saved in any effect dialog box) appear in the User Defined category in the Instant Effects palette the next time that you launch the application.
To choose an effect from the Effect Browser
Choose
Effects
Effect Browser.
The Effect Browser appears.
From the hierarchical list in the left pane, do one of the following:
To preview all effects applied to the image, click the
Presets folder.
To preview an effect category, click a subfolder of the
Effects folder (for example,
3D Effects,
Artistic Effects, or
Photo Effects).
PaintShop Pro scans the selected folder and creates thumbnails of the image with each effect applied to it.
Click a thumbnail image to choose an effect preset.
Modify the selected preset
Click Modify, and adjust the settings in the dialog box for the effect.
Note: This button is unavailable for effects that cannot be adjusted.
Resize the thumbnail preview
Choose File Preferences General Program Preferences, and click Display and Caching along the left side. In the Effect browser thumbnails group box, set a value in the Size (Pixels) control.
The thumbnail previews displayed in the Effect Browser for a given effect include the default preset and any presets that you have saved. Presets are saved as script files (with a .PspScript filename extension) and are located in the Presets folder of the main program folder. You can change the location for storing preset files. For information about changing where preset files for effects are stored, see To change file locations for resources.
