Copying and moving vector objects
You can copy and move vector objects by using Cut, Copy, and Paste commands. For more information about moving objects precisely, see To move a vector object.
To copy or move a vector object
Back to Top
Edit tab
1 On the Tools toolbar, select the Pen tool .
2 On the Tool Options palette, click the Edit Mode button .
3 Click on a contour, and then double-click one node to select all nodes.
4 Choose Objects Edit and select one of the following commands:
• Copy — copies the selected contour to the Windows clipboard
• Cut — removes the selected contour to the Windows clipboard. If the object has only one contour, the command removes the entire object.
5 Click where you want to copy or move the contour.
6 Choose Edit and choose one of the following options:
• Paste As New Vector Selection — pastes vector objects within the same layer
• Paste As New Layer — pastes vector objects as a new layer
• Paste As New Image — pastes vector objects as a new image
