Sizing and transforming text
You can transform raster and vector text interactively. For example, you can resize, rotate, shear, distort, or apply perspective to text.
You can also resize and reshape vector text by editing its nodes and contours. For more information, see Working with nodes.
Open a copy of the image.
On the Tools toolbar, choose the
Text tool
On the Tool Options palette, choose
Selection from the
Create As drop-list, and set the other text controls.
4
In the image window, click where you want to create the text selection, and type the text.
5
On the Tool Options palette, click the
Apply changes button
6
Copy the text selection to a new image.
To resize and transform text
On the Layers palette, choose a layer.
Pick tool
, and select the text.
A bounding box with handles appears on the selection or the layer.
Drag a corner handle to resize the text.
If you want to change the current proportions, right-click and drag a handle.
4
Perform any of the actions in the following table to transform the text.
Move the entire text block
Change the center of rotation
Drag the rotation pivot point.
Drag the rotation handle.
You can set a specific angle of rotation in the Angle box on the Tools Options palette.
Change the perspective symmetrically
Hold down Ctrl and drag a corner handle horizontally or vertically.
Change the perspective asymmetrically
Hold down Shift and drag a corner handle.
Hold down Shift while dragging a side handle.
Hold down Ctrl and Shift while dragging a handle.
To make the deform handles on a layer easier to see, drag the corner of the image window to make it larger than the image.
