Drawing symmetric shapes
      You can draw polygons and stars.
      To draw a symmetric shape
        On the Tools toolbar, select the
Symmetric Shape tool
        Note:  If you want to place the symmetric shape on the current vector layer, mark the
Create on Vector check box on the Tool Options palette
. If no vector layer exists, marking this check box creates one for the symmetric shape. If this check box is unmarked, the symmetric shape is placed on a raster layer. Placing a symmetric shape on a vector layer makes it easier to edit.
        On the Materials palette, click the
Background and Fill properties box, and choose a fill color.
        Click the
Foreground and Stroke properties box, and choose an outline color.
        4
        On the Tool Options palette, click one of the following buttons:
Draw Polygon
Draw Stellated
If you want to display the shape’s nodes, mark the
Show Nodes check box.
        5
        Type or set a value in the
Number of sides control.
        6
        Drag to draw the shape.
        7
        Click the
Apply button
          | Apply rounded outer corners to the shape | Mark the Rounded Outer  check box. |
          | Apply rounded inner corners to the stellated shape | Mark the Rounded Inner  check box. |
          | Set the radius for the stellated shape | Type or set a value in the Radius  control. |
      You can save Tool Options palette settings as presets. For more information, see Using and creating presets.
      You can also choose line style options such as style, stroke width, and join and miter limit settings. For more information, see Drawing lines.
