Scaling and transforming photos using the Pick tool
The Pick tool lets you transform images interactively in the following ways:
Scaling resizes an image horizontally, vertically, or proportionally.
Shearing skews an image vertically or horizontally.
Distorting an image stretches or contracts it in any direction.
Applying perspective to an image corrects the perspective or applies a false perspective. For information about correcting image perspective, see
Correcting photographic perspective.
Rotating an image moves it around a pivot point. For information about rotating images, see
Rotating images.
When you transform an image, the transformations are applied to the layer on which the image resides. You can apply transformations to any raster layer or selection.
Setting scaling and transformation options
You can precisely control many of the deform settings. The following options appear on the Tool Options palette when the Pick tool is active:
Pivot X, Pivot Y — sets the X and Y coordinates of the rotation pivot point
Position X, Position Y — sets the X and Y coordinates of the top left corner handle
Scale X (%), Scale Y (%) — sets the percentage of change for the horizontal (X) and vertical (Y) resizing
Shear — sets the offset of a side. Positive values shear to the right, and negative values shear to the left.
Angle — sets the rotation around the pivot point. The image is rotated clockwise, from 0 to 360 degrees.
Reset Rectangle button
— resets the deformation rectangle to its original shape but keeps any current deformations
Perspective X, Perspective Y — adjusts the perspective of the deformation
Note: The best way to create and adjust perspective is by dragging the control handles. When you create a perspective effect with the control handles, you manipulate many variables. Changing the values in the Perspective X and Perspective Y controls may affect the scale, shear, and position values.
To scale or transform a selection, layer, or image
Choose a selection, layer, or image by clicking its name on the Layers palette.
On the Tools toolbar, choose the
Pick tool
A bounding box with handles appears.
Perform one or more tasks from the following table.
Resize while keeping the current proportions
Resize while changing the current proportions
Right-click and drag one of the corner or edge handles.
Change the center of rotation
Drag the rotation pivot point.
Drag the rotation handle.
Change perspective symmetrically
Hold down Ctrl, and drag a corner handle horizontally or vertically.
Change perspective asymmetrically
Hold down Ctrl + Shift, and drag a corner handle horizontally or vertically.
Hold down Shift, and drag a side handle.
Hold down Ctrl + Shift, and drag a side handle.
By default, you must hold down Ctrl + Shift to distort an image. To distort an image without holding down keys, choose a different Mode setting on the Tool Options palette. The Scale mode is the default setting, so you must hold down a key or keys. The Shear mode lets you shear without holding down Shift. The Perspective mode lets you change perspective without holding down Ctrl. The Free mode lets you distort without holding down Ctrl + Shift.
When the Pick tool is active, you can scale and transform precisely by setting values in any of the boxes on the Tool Options palette.
